Setting Valve Clearance
andrew smith
07-14-2006 07:57:01
Hi i am getting ready to set the valves on my WD-6 tractor and would like to know what the clearance should be? Also where can i by a new valve cover gasket?
newpuller
07-14-2006 08:00:59
 Re: Setting Valve Clearance in reply to andrew smith, 07-14-2006 07:57:01
.017 when the engine is hot. I got one from the local IH dealer.
RustyFarmall
07-14-2006 09:35:18
 Re: Setting Valve Clearance in reply to newpuller, 07-14-2006 08:00:59
And if you can't get the engine warmed up enough, it works to set those at .020-to .025 cold.
