Farmall H Problems
Jeff Wenner
07-14-2006 08:45:35
Freind of mine had some trouble getting his H to run right last year(non-farmer & definitly non-mechanic). I told him how to adjust the carb and he got it running great again. He said it ran like a new one. He got it out to mow last week (probably first time it ran since last fall) and it ran great for about 2 hours and it srarted to blow black smoke then quit. Started it back up, ran for a couple seconds then quit again. Won't start at all now. I told him to check the air intake and carb for dirt or blockages, any ideas what could be wrong?
magman
07-14-2006 09:11:29
 Re: Farmall H Problems in reply to Jeff Wenner, 07-14-2006 08:45:35
I AGREE ON THE FLOAT OR SOME JUNK IN THE NEEDLE AND SEAT. Sorry for the caps. Clean it out with some spray carb cleaner through the inlet and let it drain through the bottom then clean the bulbe and line and check the tank for debree. JON
pensfan
07-14-2006 08:56:50
Could be a bad float in the carb, causing it to flood out.
