Farmall-A tranny drain plug?
Kendog
07-14-2006 11:47:58
I don't yet own the Op-manual, sorry. But where is the drain plug? Check level plug-found it. PTO drain plug-
found it, tranny drain plug-not sure. Thank you.
Dave BN
07-14-2006 13:15:02
 Re: Farmall-A tranny drain plug? in reply to Kendog, 07-14-2006 11:47:58
Yes, the one plug on the bottom right(under the PTO) drains the Transmission and differental and PTO. If you have a belt pulley their is a small plug on the bottom of that casting that drains that gear box and a plug on top to fill it back up. If your doing this you should drain and refill the final drives also. To do this yu remove the sheet metal pans at the bottom of the final drives, clean the pans out and reinstall them using new gaskets. Then refill thru the plugs in the casting just above the pans Dave.
Jim Becker
07-14-2006 12:45:55
One plug drains the transmission, differential and PTO.
