M Head light wireing
Paul G. in Mn
07-14-2006 13:49:19
I am makeing new wires for my headlights on my M. I am wondering if the 2 wires from each light joined at the head light bar or if they ran 2 down to the switch. Thanks Paul
Tom Windsor
07-14-2006 14:53:16
 Re: M Head light wireing in reply to Paul G. in Mn, 07-14-2006 13:49:19
One wire per light goes to ground. Join the other two to a common wire to switch. From Swithch run wire to battery terminal or to light lug of voltage regulator.
RustyFarmall
07-14-2006 15:16:28
 Re: M Head light wireing in reply to Tom Windsor, 07-14-2006 14:53:16
Farmall M and H headlights are grounded to the headlight bar. There are no ground wires.
Paul G. in Mn
07-14-2006 15:35:01
 Re: M Head light wireing in reply to RustyFarmall, 07-14-2006 15:16:28
This one happens to be a 39 so the reflector is grounded via a small screw in the rim of the light. Thanks for the input about just running 1 wire down. Paul
RustyFarmall
07-14-2006 13:56:48
I'm pretty sure thay are soldered together inside the bar, only one wire runs down to the box.
