Farmall M(NEW Amp Gauge)
ryan from WI
07-15-2006 19:43:04
I bought a new amp gauge from TSC. First when I put it in I hooked it up like it was on the old gauge. When I turned on the lights it was reading positve charge at 10 amps. Then I just said thats enough farm"in today. Now to day hooked the wires the opposite way and turn the lights on it was discharging at 10 amps. I thought that is right. So later when I was using it I had the lights on and tractor was running it said zero. Anyway is that right it seems weird to me.
Janicholson
07-15-2006 20:05:37
 Re: Farmall M(NEW Amp Gauge) in reply to ryan from WI , 07-15-2006 19:43:04
That is what you should see. The gauge is correct the way it is now. The battery is probably charged up and when running and lights on, the gen (or alt) power is just used to power the lights, none goes into the battery because it is charged. Good instsall, JimN
