IH 2000 loader on a farmall 460, will it fit?
Isaac Mempa
07-16-2006 12:36:19
Hey guys, first post here. Im looking into buying a Farmall 460 and am wondering if a IH 2000 loader will fit on it. The loader was on a IH 424. Thanks for any help.
Isaac
Weldon K
07-16-2006 14:40:48
 Re: IH 2000 loader on a farmall 460, will it fit? in reply to Isaac Mempa, 07-16-2006 12:36:19
2000 Loaders will fit on 460 tractor if the loader has correct front and rear mounting parts. The loader on a 424 cannot be installed on a 460 "as is".A 2000 loader on a 424 has very much different front mounting brackets from that used on a 460. Also the loader frame used on a 424,I believe,may not be as long as the one needed for a 460 .And, the subframe to rear axle housing attachments are different, too. All this info from Operator's manual for 2000 loader.
Isaac Mempa
07-16-2006 16:53:16
 Re: IH 2000 loader on a farmall 460, will it fit? in reply to Weldon K, 07-16-2006 14:40:48
Well that is bad news. Especially as I just rented a trailor to go get the tractors tomorrow. Is this something that would not be recomended as far as trying to make the loader fit? Would it be too much work? Thanks.
Isaac
Weldon K
07-17-2006 07:30:57
 Re: IH 2000 loader on a farmall 460, will it fit? in reply to Isaac Mempa, 07-16-2006 16:53:16
If you have capability to fabricate necessary brackets it would not be difficult. You would need a pattern and measurements to go by. Modifying the subframe to fit the rear axle may require lengthening it by adding necessary length of 4x4 tubing. The butt plate which rests against the axle housing might need to be reworked (change shape of it, drill new holes ). The front mounting brackets could be fairly simply constructed with steel plate and angle . If you want, I can send you pages from Operator's manual showing drawings of mounts for various tractors. I have a 2000 loader on a F-856 and a 2001 on a I-504 and can make photos of brackets . The 856 front brackets are built of two separate parts, bolted together, to make a right side assembly and then another assembly for the left side. Brackets needed for a 460 are very similar to these. Rear mounting on the 504 is the same as needed on 460.With pages from manual ,photos and measurements that I can give you ,you could make them yourself or have them built . Reply here if interested. Weldon
