Rear Rims On A H Farmall
kfox
07-18-2006 05:29:40
I have new rims for my H, but I think I might have a problem. The new rims have about 1/8 inch clearence all the way around the hub. The old rims were a snug fit on the hubs. I don't have any experience with tractor tires rims, and I was wondering if the new rims are going to be hard to center on the hubs. Is there any tricks to this?
ken
Magman
07-18-2006 08:03:29
 Re: Rear Rims On A H Farmall in reply to kfox, 07-18-2006 05:29:40
they should be fine just tighten the lugs a half to 1 turn at a time all the way around so its even and no tight high spots. If the rims are the new ones that fit JDs also you may need to go to a longer bolt in the hub to get them centerd right. alot of the new rims are 1" wider in the center so they will fit a # of different aplications and they are the ones that need a longer bolt for the hub. JON
dej(JED)
07-18-2006 05:39:58
I have seen them with clearance and without any. They will work just fine. Some of the early H & M's even crried a 36 inch rim, tire and wheel, which will interchange with a 38 inch set up.
