poliarity of IH B
wilson
07-18-2006 14:51:14
Fellow wants me to work on his B battery gone cables gone What is the polarity????
Red Dave
07-18-2006 17:06:23
 Re: poliarity of IH B in reply to wilson, 07-18-2006 14:51:14
From the factory it was 6 volt positive ground.
What it is now, 60 plus years later? Hard to say, but Toro gave some good ways to figure it out.
El Toro
07-18-2006 15:20:03
If the tractor has battery ignition with a distributor, check the coil terminal wire from the coil to the distributor. The + plus terminal
wire on the coil should be to the distributor when the battery is + plus grounded. Hal
El Toro
07-18-2006 15:14:42
If the tractor still has the 6 volt system, the battery would be + positive grounded. Hal
