706 German Diesel value
HossW
07-20-2006 20:10:26
Hey guys,
I just looked into a 706 german diesel, narrow front, rear tires checked but fair(18.4x34's). It has a knock in the engine, possibly a rod bearing, injection pump needs rebuilt, had a hole punced in radiator, had the line pinched off by a radiator shop, tinwork fair,flat top fenders, needs batteries. Comes with a paulsen loader, with no bucket, and a wore out 3 point blade. He says scalper told him $2000....I say $750. What's your take? Thanks.
Hoss
HossW
07-21-2006 13:46:54
 Re: 706 German Diesel value in reply to HossW, 07-20-2006 20:10:26
Thanks guys, I was just checking, only problem is it is my great grandfather's tractor. He didn't buy it new or anything like that, but I just don't think I would have a positive equity situation regardless of sentimental value! I wasn't sure of the parts availabilty. I would almost be better off to retrofit a different engine and sell the 310. Thanks for the responses.
Hoss
Marv
07-21-2006 07:50:09
I've overhauled two 756 D310's recently. If the block and head is good, the engine overhaul will run $1200 for parts and another $1200 for labor. If the cam bearings need to be replaced, figure another $300. because the replacements will need to be linebored when refitted. May as well figure another $2500 for the TA, clutch and pressure plate. Figure at least $500 for the injection pump. I nrecommend a out of frame overhaul. Marv
K.B.-826
07-20-2006 21:14:12
I'm afraid you won't get that one dirt cheap. Those engines are in pretty good demand for repowering gas tractors. Worst part is that you'll probably end up spending $10,000 by the time you do a full overhaul, radiator, and the injection pump, it will still need tires, and you won't even know what kind of shape the TA and hydraulic system is in. You could have just short of $20,000 into it all said and done.
K.B.-826
07-20-2006 21:11:57
darrenh
07-20-2006 21:07:36
I bought one for $1900 canadian but the shift was broken head gasket went radiator got hole in
it & replaced 2 injectors i think it would be worth about 4500 know but you would need to find
out what the knock was about.
sammy the RED
07-20-2006 21:00:31
$1500.00 - $2250.00
the tractor vet
07-20-2006 20:44:55
Yep she would scrap for that or even more .
jpsepp
07-21-2006 07:08:10
 Re: 706 German Diesel value in reply to the tractor vet , 07-20-2006 20:44:55
The german diesel is a great engine. The only draw back is they cost a mint to over haul. When I worked a the dealership we had a combine with the 358 german diesel and a short block was over 5000.00 in 1997. They sound and pull good.
steveormary
07-21-2006 10:31:46
 Re: 706 German Diesel value in reply to jpsepp, 07-21-2006 07:08:10
HossW Split the difference and fix-er-up. It will make you a good tractor and you will know what you have in it.
steveormary
