camshaft in DT-466
Yellott Canby
07-20-2006 20:10:31
Hello, This is slightly off the subject of tractors but I will check with you all anyway. Have a DT 466 in an IH truck that has to have a valve job and the cam changed out. Was wondering if the cam bearings could be changed without having to remove the engine and take it all apart? Thanks for the help , YC
the tractor vet
07-20-2006 20:43:07
 Re: camshaft in DT-466 in reply to Yellott Canby, 07-20-2006 20:10:31
Well that depends on how good ya are at gettin the oil holes lined up . It can be done , but i would drop the oil pan. The hard part is getting the back bearing out and not knocking out the soft plug.
Yellott Canby
07-21-2006 05:23:27
 Re: camshaft in DT-466 in reply to the tractor vet , 07-20-2006 20:43:07
Thanks for the note. If the cam and cam bearings going back in are new do the bearings have to be honed?
