Mounting tires SMTA
GordoSD
07-21-2006 06:37:53
Got new rear Firestones for the SMTA. New tubes also. What are the pros and cons of where to locate the valve stems. Inside or outside?
Gordo
dej(JED)
07-21-2006 10:19:35
 Re: Mounting tires SMTA in reply to GordoSD, 07-21-2006 06:37:53
I have mostly seen them on the outside. If you put them on teh inside , they are less likely to get ripped off.
Farmer Bob
07-21-2006 07:13:33
Only con of putting them on the inside is the inconvenience of airing them up without rotating the tire some to get the stem into a better location. I'd put them on the outside.
