M farmall manifold threads
biggerred
07-21-2006 11:09:03
What size pipe tap do I need to re-thread a manifold on am M?
randy hall
07-21-2006 13:50:28
 Re: M farmall manifold threads in reply to biggerred, 07-21-2006 11:09:03
2" NPT i rethread them at work on a six foot radial arm drill press. it takes a lot of power to turn the tap in as deep as it should be. i have never broken a manifold yet doing this.
Wardner
07-21-2006 13:30:55
Often times they don't need to be rethreaded. The threads fill up with soot and rust and seem to disappear. If the manifold is off the tractor, take it to a machine shop and get the outlet sandblasted/glass-beaded. They will probably chase the threads for no additional cost. In any event, you should take the manifold off and replace the studs, washers, gaskets, and brass nuts.
If you do it yourself, you will degrade the 2" pipe tap (not cheap) as it is cutting through the hard oxides. You could even wind up with a cross-thread. I wouldn't let you borrow my tap. Sorry.
RustyFarmall
07-21-2006 11:30:13
Two inch
the tractor vet
07-21-2006 11:29:43
2 inch i will tell ya that it will be some hard cutting .
RustyFarmall
07-21-2006 11:32:22
 Re: M farmall manifold threads in reply to the tractor vet, 07-21-2006 11:29:43
We answered at the same time, and you're right, it is tough. Best to have the manifold still mounted to the tractor, and even then you might move the tractor.
IH2444
07-21-2006 11:37:13
 Re: M farmall manifold threads in reply to RustyFarmall, 07-21-2006 11:32:22
Uggh that sounds brutal. Break any manifolds when threading them ?
Need to do my tractor, might just get a new manifold for about $125 after reading that.
RustyFarmall
07-21-2006 13:15:40
 Re: M farmall manifold threads in reply to IH2444, 07-21-2006 11:37:13
It only gets tough when you have to go deep enough to cut some new threads. Just cleaning up what is already there is only about half that tough, still a better option than an aftermarket manifold that may or may not fit.
