M Won't Run Right
Andy Martin
07-22-2006 12:08:08
I had my grandfather's M tore apart all spring rreplacing the front bolster bushings and radiator. The manifold also needed flattening because it was leaking at the two center exhaust ports.
It hasn't run right since I got it back together, had to choke to start it and it would not pull any load. I tore the carburetor down today to clean out what had gotten dislodged. What I found was a mud dauber's nest almost completely plugging the venturi!
It is really nice when you take something apart and find a problem.
unioncreek
07-22-2006 19:39:17
 Re: M Won't Run Right in reply to Andy Martin, 07-22-2006 12:08:08
Andy,
Yes, it's nice to find out what is wrong with something. If you still have the carb apart buy some carb cleaner and soak it up good and let it set overnight to get everything clean.
Bobg
