574 Questions
Retcol
07-22-2006 14:40:17
How much is an International 574 Utility worth? Also, how difficult is it to repair the parking brake? What are some of the weak point on the tractor that I would need to be concerned?
FromJB2
07-22-2006 18:44:21
 Re: 574 Questions in reply to Retcol, 07-22-2006 14:40:17
Hi Retcol, here is my thoughts on replacing the parking brake band:
My brother's 684 has the same problem, he asked a former IH mechanic about replacing the band and here is his answer: It is not worth replacing the band without replacing the drum as the drum will be scored and the new band will not hold. To replace drum requires many $$ splitting tractor at rear and taking top off where seat and 3 pt hitch sit on transmission.
His simple solution is to buy all thread bolt with eye on end, drill a hole on floor board and mount bolt so eye of bolt comes up between brake pedals. To park tractor press brakes down and put a pin thru the eye to hold brakes on.
Works great.
JB2
