SMTA Voltage Regulator
Retcol
07-23-2006 07:02:09
I think I need a new voltage regulator on my SMTA. Most often when I start it the amp gauge needle doesn't move until I tap on the voltage regulator. Also, I notice there is some acid residue in the new battery box. Is that caused by the regulator starting to cook the battery? The tractor has been converted to 12 volt. Do I need a 12 volt regulator?(Don't know anything about tractor electrical systems.)Do I need to buy a regulator from a Case IH dealer?
Janicholson
07-23-2006 07:09:13
 Re: SMTA Voltage Regulator in reply to Retcol, 07-23-2006 07:02:09
Tapping a regulator to get it started is an indication, as you have determined, that it is on its way out.
Yes a 12v regulator is needed. Check the polarity of the ground to specify that to the seller.
No NAPA, or other distribution resellers have the correct component. Match your old one (because it was working) JimN
RustyFarmall
07-23-2006 07:26:02
 Re: SMTA Voltage Regulator in reply to Janicholson, 07-23-2006 07:09:13
Why would NAPA not have the correct component? The tractor has been converted to 12 volts, that means the charging system already is not stock, and since it is not stock, IH may or may not have the proper components. NAPA would be my first choice for a replacement 12 volt voltage regulator.
Janicholson
07-23-2006 15:34:58
 Re: SMTA Voltage Regulator in reply to RustyFarmall, 07-23-2006 07:26:02
Sorry rusty I clicked send before I read the response I made. I left out a comma and assumed I was saying no to his question and not to NAPA who I have magnum level respect for. NAPA surely has them.
RustyFarmall
07-24-2006 06:54:11
 Re: SMTA Voltage Regulator in reply to Janicholson, 07-23-2006 15:34:58
I thought maybe that's what happened, sometimes our fingers go faster than our brains.
