Final drives
Murray E
07-23-2006 17:52:20
One question for this evening,removed the final drives pan's this evening.The final drive on the left side appears to have a slight movement of prephaps 1/8 of an inch. The right side has no movement at all. Is this serious??. what is my next step? Thanks , Murray
john *.?-!.* cub owner
07-25-2006 07:04:21
 Re: Final drives in reply to Murray E, 07-23-2006 17:52:20
you didn't mention what modle tractor you are referring too, but most of them have shims to limit the gear form moving side to side, if that is your problme they mey be worn or missing. If it is wobble you will have to take it apart to verify if gear or shaft
Steven@ND
07-23-2006 20:48:13
I assume this is on an A or B?
Which way is the movement? Is it gear lash or side to side movement?
Either way I would disassemble that final drive and look for a bad bearing or torn up gear.
Roger46
07-23-2006 18:28:18
What kind of a tractor is this? That much play seems excessive in that either you have a bad bearing or the nut on the bull gear has come loose.
