Farmall A Cast Center Weight
flic50
07-23-2006 18:28:30
Hello all, does anyone know what the heavy cast wheel center on the right rear side weighs? I looked in the archives and didn't see the weight. Thank you;
Hugh MacKay
07-24-2006 03:11:37
 Re: Farmall A Cast Center Weight in reply to flic50, 07-23-2006 18:28:30
flic50: My Farmall 130 manual calls the wheel weight 145lbs. I think the cast center is very close to the same weight. Like Haas I think i've read that somewhere over the years. Also from handling and having changed and rearranged my wheels over the years, I would judge the two to be very close in weight.
HAS
07-23-2006 20:29:59
Someone posted on here about a year ago that it is 150 lb.
Charles McNelly III
07-23-2006 18:53:38
Well, the rear add on weights on the B weigh around 132 lbs. I would imagine the hubs would be around 200 lbs. Just a guess. Charles
