roll over
Carlton
07-23-2006 19:06:05
I have a 300 farmall row crop and was wondering what angle hill is farmable and safe without a rollover? When the tire goes up na little It makes me wonder and I've been driving tractors since I was 14.
Carlton
riverbend
07-24-2006 20:45:04
 Re: roll over in reply to Carlton, 07-23-2006 19:06:05
Theory is that when the center of gravity gets outside the line between the front tire and the rear tire, the tractor will tip over. The center of gravity is probably near the top of the torque tube. I try to keep the top of the hood inside the tire tracks.
Allan In NE
07-24-2006 02:31:12
Hi Carlton,
I know what ya mean. I had a tractor come up on me many, many years ago; half a lifetime ago, in fact.
I still get the shudders just thinking about it!
Be safe!
Allan
Steven@ND
07-23-2006 20:46:07
I agree with what was said, "If you have to ask, it's too steep!"
If you are unsure, stay away - it isn't worth your life!
All it takes is a mole hill or a badger hole to roll a tractor in an iffy situation.
CNKS
07-23-2006 19:43:31
In my opinion, if you have to ask, then the slope you are thinking about is not safe. I drove a tractor on a rather steep terrace one time. It got steep enough so fast that I stopped the tractor, got off and found someone to move it for me. If you have driven tractors that long, you probably already know. Problem is, you never know when a wheel is going to fall into a hole, turning an otherwise "safe" slope into a disaster.
wolfman
07-23-2006 19:14:10
For starters, widen the wheels out on the axles to about 8 feet. At that width it will work on pretty steep ground. When you look straight down from the seat and see the inside sidewall of the low side tire, it's too steep !
stiknrudder54@aol
07-23-2006 22:34:21
 Re: roll over in reply to wolfman, 07-23-2006 19:14:10
do you also move the front wheels out and if so how far will they move?
Carl
wolfman
07-24-2006 19:12:36
 Re: roll over in reply to stiknrudder54@aol, 07-23-2006 22:34:21
Yes. widen the fronts to the point that if you drove it in snow the inside half of the rear tires would cover the front tire tracks.
carlton
07-24-2006 21:19:27
 Re: roll over in reply to wolfman, 07-24-2006 19:12:36
thanks for all the info guy's! I have widened the rears and the fronts are like wolfman said. I keep it safe as I like to live a lot longer! although I still break horses so I need to re think my ways.
thanks again !
Carlton
Clancy mt.
