544 pto shaft oil seal replacement
andyr
07-23-2006 23:11:38
Well, unforunately I wrapped some grass up on the PTO shaft while mowing and it damaged the oil seal so that it drips. My question is, can the oil seal on a 544 utility be replaced without taking the PTO unit out and disassembling it. It looks the seal can be pulled out and replaced simply without dissassembly. Is this the case? Thanks. andy
kfox
07-24-2006 09:30:34
 Re: 544 pto shaft oil seal replacement in reply to andyr, 07-23-2006 23:11:38
Don't know about the 544, but on a H its fairly easy. Drive the front end down in a ditch and you wont even need to drain the oil. (also checks your front seals at the same time:-) ) ken
