Farmall M Alternator Belt
Wisconsin Cowma
07-24-2006 10:47:28
The alternator belt on the M is looking bad. Now this tractor was converted over to 12 volt before I got it. Anybody know the size of that belt or a part number. Would like to know cause it is on it's last days. Thank You
Haas
07-24-2006 14:57:25
 Re: Farmall M Alternator Belt in reply to Wisconsin Cowman , 07-24-2006 10:47:28
Take the belt off and go to an auto parts store such as NAPA or Autozone. You should be able to get a replacement belt the same as the one you have. Each installation of the retrofit alternator is likely to be a little different, so you are going to have to just go with finding one like you have.
Andy Martin
07-24-2006 11:11:39
Your best bet is to cut the belt, take it in and get a replacement. Most alternator installations require the "right" belt length, and the length required is based on how the brackets were made.
dej(JED)
07-24-2006 11:02:47
Most belts have a number on them.
El Toro
07-24-2006 10:53:46
If that was the original generator belt the Gates number 9355 or 9355HD heavy duty belt. Hal
