544 international diesel industrial
mike mosty
07-24-2006 11:06:43
did I screw up? After overhauling my hydro I'm having troble stating the engine. If I get it started-which takes forever since it turns over hard now- it runs for 4-5 seconds and quits like the fuel was shut off. Am I getting a pressure build-up? Any idea why it turns over hard-didn't before I changed the hydro and started fine. The only thing I can think of is a bind or pressure from the aux.hyd. or hydro unit
Allan In NE
07-24-2006 11:26:56
 Re: 544 international diesel industrial in reply to mike mosty, 07-24-2006 11:06:43
I'd put 'er in neutral and throw the stick clear ahead to see if that loosens it up.
Or, maybe place a jack under the center of 'er and loosen the split bolts a half a turn. See if that makes any difference. Did it pull together hard? Maybe that input gear is on a bind.
Could the battery just be weak from setting all that time and maybe we have a little air in the fuel system?
Allan
