Farmall A - B Rear end bolts? or Studs?
Midwest Boy
07-24-2006 18:34:25
I have a question on the rear pto and belt pulley gearbox and plate on the rear end of an A or B. I have one tractor that has 5 (7/16 bolt ..5/8 head) and my other has 3 of the same bolts, BUT HAS 2 STUDS and then 2 nuts. My question is that are they studs or are they permenant to the tractor's rearend. I would like to put a bellow mounted sickle mower and the way to hook it on the back is with 5 long bolts, but with those studs it might not work. Thanks and God Bless
oshkosh
07-25-2006 05:34:23
 Re: Farmall A - B Rear end bolts? or Studs? in reply to Midwest Boy, 07-24-2006 18:34:25
Hi Midwest- My B has the bolts. I've not seen one with studs before. If it were me I'd slowly back the studs out and see what they look like. Maybe you can replace with bolts to use your sickle bar? Good luck.
El Toro
07-25-2006 07:39:17
 Re: Farmall A - B Rear end bolts? or Studs? in reply to oshkosh, 07-25-2006 05:34:23
Oshkosh builds some fine trucks. Hal
