560D hydraulic oil change
toolz
07-24-2006 20:18:49
I drained my hydraulic oil this weekend- had the normal milky-yellow mess. I removed the rear plug and the plug under the T/A housing. I also drained the PTO housing and the filter cover. The small plug at the front of the trans housing is not going to come out. How much oil will I leave in if I don't remove this plug? I also jacked up the front of the tractor to drain the trans housing better. Thanks again- KB
K.B.-826
07-25-2006 21:57:33
 Re: 560D hydraulic oil change in reply to toolz, 07-24-2006 20:18:49
Get a punch and a big hammer. Try to turn that plug out by beating the hell out of it. Failing that, carefully heat the plug and let it cool, it will come right out. If that doesn't work, it's time to drill it out. You need to get all of that oil drained. Watery oil is a disaster waiting to happen.
