Electrical question
Guff
07-25-2006 10:13:25
My 51 "H" has been converted to a 12 volt system, has an automotive altenator and separate voltage regulator, but still has the original 6 volt coil (and starter). I think it is going out. My question, if I replace with an automotive 12 volt coil do I get one with a built in resistor or without? Or is there resisitance in the wiring? One guy says there has to be resistance or the points will burn up? My local old tractor guy has a John Deer 12 volt replacement coil for $14 bucks, from the same time period. He thinks it will work fine?
Any help is appriciated...
John T (Ballast Basics)
07-25-2006 15:59:01
 Re: Electrical question in reply to Guff, 07-25-2006 10:13:25
Guff, Bob and Bob M and myself n others have covered this in great detail often before but I will lay it all out once again for future reference.
BALLAST RESISTOR BASICS
QUESTION: My question, if I replace with an automotive 12 volt coil do I get one with a built in resistor or without?
ANSWER: If you replace it with a coil AND DONT WANT TO USE ANY EXTERNAL BALLAST RESISTOR it must be a full true 12 volt rated unit. They are often labeled "12 Volts" or "12 Volts No Ballast Required" CAUTION DO NOT use one labeled "12 Volts for use with an external ballast resistor" cuz its in effect a 6 volt coil and will overheat UNLESS it has the added external ballast.
ANSWER: Most 12 volt coils DO NOT actually have a "built in" resistor. They are 12 volt coils cuz the resistance of their primary winding is in the 3 ohms range versus say 1.5 or so ohms range found in 6 volt coils. They have more primary winding resistance cuz they have more wire length and/or the wire is higher in resistance itself. NOTE: 12 Volt coils are often referred to as "Internally Ballasted" for the reasons described above
QUESTION: Or is there resisitance in the wiring?
ANSWER: Its true some auto manufacturers used resistive wire links but thats NOT a common thing on tractors, if they required external ballast, they generally used the regular old ceramic/porcelain bathtub style wirewound units. So, the answer is theres likely NOT resistance in the wiring.
QUESTION: One guy says there has to be resistance or the points will burn up?
ANSWER: Its indeed true that ifffff f you use a 6 volt coil on a 12 volt tractor and dont use any external voltage dropping (12 to 6) current limiting ballast resistor, the points will burn up quickly PLUS the coil will overheat n be damaged also. Sooooo He's right, if you use a 6 volt coil on a 12 volt tractor YOU MUST ADD SERIES BALLAST
QUESTION
ANSWER: Assuming its a true full 12 volt rated (internally ballasted) coil and labeled "12 volts" or "12 volts NOT for use with an external ballast" etc or "12 volts NO ballast required" YES IT WILL WORK
KETTERING COIL IGNITION THEORY:
A coil is more of a current device then a voltage device. When current passes through its primary winding energy is stored in the magnetic field and when that current is interrupted (points open) the field collapses and voltage gets induced over into the high voltage secondary winding. THE REASON FOR THE USE OF CURRENT LIMITING BALLAST when you use a 6 volt coil on a 12 volt tractor is to limit BOTH the coil and points current to around the 3 to 4 amp or so range OTHERWISE the points burn up quickly (thats the weak link) and if the coils current is greater then it was designed for (like if you apply 12 volts to a 6 volt coil) it will overheat and go bad. THEREFORE in order to limit coil and points current to say 4 amps if you use 12 volts and have a 6 volt coil YOU MUST ADD EXTERNAL BALLAST so the total resistance (coil plus ballast) is around 3 ohms 12/3 = 4 amps BUTTTTT TTTTT IF THE total resistance of the 12 volt coil alone is in the 3 ohms range, then current is 12/3 = 4 amps again so all is well
THE DIFFERENCE in a 6 and 12 volt coil is the primary resistance, a 6 is around 1.5 ohms while a 12 (internally ballasted) is around 3 ohms, so the points current is in the 4 amps range so they dont burn up prematurely.
As far as stored energy n how hot the spark is, since the coil is more a current then any voltage device (Its an inductor and they store energy in the magnetic field produced when you pass current through a coil of wire) and since theres still around 4 amps passed through EITHER a 6 volt or a 12 volt coil with an external ballast, either set up can in theory develop approximately the same spark gap energy as the other.
NOTE: The points n condensor would be the same REGARDLESS if used on a 6 or 12 volt cuz their voltage withstand rating is wayyyyy y higher then 6 or 12 volts anyway.
BOTTOM LINE: On a 12 volt tractor you must EITHER use a full true 12 volt rated (internally ballsted has around 3 ohms resistance) coil OR ELSE if you use a 6 volt coil (around 1.5 ohms resistance) YOU MUST ADD SERIES VOLTAGE DROPPING (12 TO 6) CURRENT LIMITING EXTERNAL BALLAST RESISTANCE (around 1.5 ohms) or else the coil overheats PLUS the points burn up quickly. The choice is yours and the spark gap energy wont be all that much different as explained above.
If you wish I can dig out an artice on Ballast Resistors I wrote for the Green Magazine and e mail it to you, let me know.
Hope this explains the whole Ballast Resistor thing so post back any questions or questions about the ballast by pass staryt systems on tractors that used it.
Best wishes n God Bless all here
John T retired Electrical Engineer
Guff
07-25-2006 15:29:49
As far as I can tell, there is not a resistor wired in between my coil and the ignition switch. So that would mean that I need a coil with built a bulit in resistor?
Nebraska Cowman
07-25-2006 10:23:07
I get slammed when I say it but as far as I know there is no such thing as a 12 volt coil. either it is a 6 volt coil requiring a resistor to use with 12 v systems or it is a 6 volt coil with internal resistor designed to use on 12 v systems without adding the resistor. Only you can trace the wire back to the switch and see if thhere is a resistor installed.
third party image
Gold for the mistress,
Silver for the maid.
Copper for the craftsman,
Cunning in his trade.
"Good" said the Baron sitting in his hall,
"But iron- cold iron - is the master of them all."
-Rudyard Kipling
John T
07-25-2006 18:49:39
 Re: Electrical question in reply to Nebraska Cowman, 07-25-2006 10:23:07
Cowman, for sure you wont get slammed from me, theres a lot of truth in what you say. A 12 volt coil has around 3 ohms of resistance in the primary while a 6 volt coil has but around 1.5 ohms. In the 12 volt it either has wire of a higher resistance or else more of it which is why it has 3 ohms of resistance. They may have made some coils that actually had a resistor built in but most all Ive seen and am familiar with have none but instead just more wire or wire having more resistance. The reason they make n use 6 and 12 volt coils and the reason why extra series external ballast is required if you use a 6 volt coil on a 12 volt system is to get a TOTAL of 3 ohms in the primary circuit (coil PLUS any ballast) in order to limit the current the points must switch to around 4 amps or so max so they dont burn up prematurely. So the so called 12 volt coils may not be able to store much more energy then the 6 although there are indeed DIFFERENCES in 6 and 12 volt coils in the difference in the resistance of the primary windings measured between their lil + and - terminals.
Hope this helps yall. Best Wishes n God Bless
John T
Gary in Mozarks
07-25-2006 13:52:44
You are correct
Allan In NE
07-25-2006 10:54:39
Yep,
That's just some more of your hands-on common sense shinin' thru.
Coils, condensers and starters can't see voltage and could give a fig less. As long as they have enough insulated "turns of the wire", they'll work. :>)
Allan
RustyFarmall
07-25-2006 10:29:07
Cowman, I have to agree with you. Even up into the late 60s and into the 70s, on all of the cars, trucks, and tractors that I am familiar with, the ignition coils operated on 6 volts, either internally resisted, or externally with a ballast resistor.
Joe Kimbriel
07-25-2006 10:49:25
 Re: Electrical question in reply to RustyFarmall, 07-25-2006 10:29:07
Cowman is correct. Coils do not have voltage they have internal resistance. If a coil has enough internal resistance to handle 12 volts with out getting hot then it can be considered a 12 volt coil. If the coil gets hot with 12 volts then a dropping or ballast resistor must be added. With the resistor added externally, normally the voltage at the coil will be somewhere around 6-7 volts. With the resistor added externally also allows for the starter relay to give full 12 volts to the coil when starting for a hotter spark.
Does this make any since, hope so?
The answer, will the JD coil work? Maybe, with a good understanding of you electrical system resistor or no resistor internal or external.
John T
07-25-2006 18:53:35
 Re: Electrical question in reply to Joe Kimbriel, 07-25-2006 10:49:25
Yep, it does indeed make sense. One advantage of using a 6 volt coil with an external ballast resisitor on 12 volt tractors is the ability to use the start ballast by pass circuit which indeed yields a hotter starting spark which is unavailable on a 12 volt internally ballasted coil.
Take care n God Bless yall
John T
Andy Martin
07-25-2006 11:01:02
But the point he was making is that all coils are wound the same. Some marked 12v have an additional internal resistor and some don't. The actual winding is still designed for 6v differential. It is hard to understand why a 12v coil would need an external resistor but that's what GM did with their resistor wire. I buy replacement coils for GM cars because I know they do not have an internal resistor and are truly 6v coils so they go well with a ballast resistor.
Bob
07-25-2006 23:03:03
 Re: Electrical question in reply to Andy Martin, 07-25-2006 11:01:02
Andy Martin,
If you can prove to me the existance of a modern "12-Volt" coil with an "additional internal resistor" that's "wound the same as a 6-Volt coil", I'll buy you a steak dinner!
We are talking here about a commonly available coil for a Kettering ignition system using breaker points.
The actual fact is that there is NO "discrete" internal resistor in 12-Volt coils. The extra resistance comes about through many extra winding turns in the primary of the "12-Volt" coil, vs. the primary of a "6-Volt" coil.
The internal "resistor" myth keeps popping up, but AFAIK, it has NO basis in fact.
As another poster stated, the reason a coil and external ballast resistor combination was used was to allow a "starting bypass", where full battery voltage was fed to the coil, bypassing the ballast resistor during cranking, to maintain a hotter spark while the available battery voltage is being reduced by the current demands of the starter.
Another topic not covered is "PTC" (positive temperature compensated) ballast resistors. Their resistance starts out low, and more or less doubles over a period of a minute or so after startup. This gives a HOT spark for cranking, then heating of the resistor causes it's resistance to rise, making life easier for the coil and breaker points.
As a general rule, systems using a starting bypass used a fixed-value ballast resistor.
Systems NOT using a starting bypass often used a "PTC" ballast resistor.
Andy Martin
07-26-2006 05:40:42
 Re: Electrical question in reply to Bob, 07-25-2006 23:03:03
Guess I was perpetuating a myth. I've never actually torn one open to know. I've always used GM coils knowing what they were but now there seems to be lots more coils available than a few years ago.
I would buy you a steak dinner, though. How close to Tulsa are you.
Bob
07-26-2006 08:54:35
 Re: Electrical question in reply to Andy Martin, 07-26-2006 05:40:42
About an hour S.E. of HERE:
IH2444
07-25-2006 11:13:13
Chrysler produckts also had a lot true 6 volt coils on them.
I wonder if some of these new coilpacks on vehicles are true 12V coils? They are hot suckers, that is for sure.
Allan In NE
07-25-2006 11:39:36
 Re: Electrical question in reply to IH2444, 07-25-2006 11:13:13
Yes Sir,
You've got it. The more "wraps of the wire", the hotter the spark thrown.
Allan
IH2444
07-25-2006 13:19:32
 Re: Electrical question in reply to Allan In NE, 07-25-2006 11:39:36
And of course doubling the input voltage to the actual coil not thru a resistor pretty much doubles the output as well.
Gary in Mozarks
07-25-2006 13:56:02
 Re: Electrical question in reply to IH2444, 07-25-2006 13:19:32
Yep, lots of systems run 12 volts through the coil when the key is in the CRANK posistion and 6 volts when its in RUN. Sure helps on those cold winter mornings.
IH2444
07-26-2006 06:20:37
 Re: Electrical question in reply to Gary in Mozarks , 07-25-2006 13:56:02
Yes Gary, if you have an engine that starts fine but then immediately dies as soon as you release the key, check the ballast resistor.
