Overdrive for farmall C, super C, 200?
A Taylor
07-26-2006 01:29:40
Hello
does anyone know if there is a overdrive unit small enough that will fit into the torque tube of a farmall super c?
This little tractor is ran quite a bit on the road, and could use a little more speed. (after I find a wide fron end)
if anyone has experience in this please let me know. Ford 8N owners should not have ALL the fun!
gene bender
07-26-2006 02:24:39
 Re: Overdrive for farmall C, super C, 200? in reply to A Taylor, 07-26-2006 01:29:40
none was ever made but you could always make one as there is plenty of room to fit one. Have thought about doing that sometime on a B as the same basic tube is used. Dont need a wide front do do that. Just get the steering fixed on the narrow front. We ran the Hs and Ms in roadgear without wide fronts same a s all the other tractors some went fast like SILVER KING without wide fronts.
Easy1
07-26-2006 05:38:22
 Re: Overdrive for farmall C, super C, 200? in reply to gene bender, 07-26-2006 02:24:39
I have seen Silver Kings at shows, didn't know that they were fast? I read that Friday tractors were ( are?) quite fast - 40 mph? I have read of overdrive units made up running off the pto? Never seen one. Sound dangerous in a tractor with no real suspension, my H and 300 go faster than I want on gravel roads.
