Replacing stater on a 300U.
Easy1
07-26-2006 05:33:28
My starter went out on my 300U. I had it rebuilt, but my question is, should I lube the bendix gear before I replace it?
olderguy
07-26-2006 05:52:05
 Re: Replacing stater on a 300U. in reply to Easy1, 07-26-2006 05:33:28
go ahead and lube the starter shaft when you put the starter drive on.
Easy1
07-26-2006 08:22:22
 Re: Replacing stater on a 300U. in reply to olderguy, 07-26-2006 05:52:05
Thanks - I was thinking the gear too?
olderguy
07-26-2006 14:59:41
 Re: Replacing stater on a 300U. in reply to Easy1, 07-26-2006 08:22:22
I lube the shaft but not the gear, have not had problems with dirt but thats just my experience
old
07-26-2006 09:30:40
My self I never lube ay of it, the reason why is that dirt etc then sticks to things and the bendex can/will hang up and not owrk correctly. You can use a dry lube but I wouldn't use oil or grease
