Farmall 340 overbore kit?
K potter
07-26-2006 13:35:56
Does anyone make a farmall 340 (gas) overbore kit?? I can't find one anywhere. If you know anywhere that I could find one, I'd really appreciate it.
El Toro
07-27-2006 18:05:16
 Re: Farmall 340 overbore kit? in reply to K potter, 07-26-2006 13:35:56
The engine is similar to the C123 engine in the Super C and some of the Super A's that can be boosted to 3.25" bore. It's probably like what Jim has said about the block being maxed out. Hal
Janicholson
07-27-2006 12:15:19
The reason may be (I'm not certain) that the engine is already maxed in geometry. Cylinders can't get larger. That engine is from the same origins as an A,B,C 113 CID. Any thing is possible, so hot rodding it can be done with special boreing, and sleeves from a site like LA Sleeves, and custom pistons. Good luck, JimN
