Order Farmall Cub Parts Online
Cub Starter
mwkellner
07-26-2006 22:44:48
I discovered today that the bendix on my (Grandad's) starter is stuck in the out position when I used the hand crank to turn the motor over and heard a ratcheting sound from the starter. I took the starter out of its case(?) and can't seem to find any way to get the bendix back down (because I don't know much about it). Is there any tricks to this, or does it need to be taken into the starter shop?
I also noticed that the engine seemed very easy to turn over. I could BARELY feel the compression strokes (as compared to a C or SC). Is that normal for a Cub, or should I check the compression?
Thank you for any help that y'all can give me (again). -- Martin
john *.?-!.* cub owner
07-27-2006 10:13:14
 Re: Cub Starter in reply to mwkellner, 07-26-2006 22:44:48
You didn't mention how long since the tractor was last run, but i am assuming quite a while. The bendix is jsut a apral groove to run it out, and should move easily. may be rusted. The pistons on a cub aren't near as big as a Super C, etc. but still hould have noticable compression. if ti hasn't been run in several years, the rings oor valves may be stuck., or just need a little oil ot sela them.
Wayne Swenson
07-27-2006 06:06:54
The Bendix should easily return to the "at rest" position. Try tapping on it & use a drying lube (WD-40) to see if you can get it to move.
Compression is not great to begin with. How long since it ran? Remove the spark plugs & squirt some engine oil in each cylinder, crank over a few times, replace the sparkplugs, & try again.
