Oil pressure Gauge line Fitting
Elk Farmer
07-27-2006 12:05:50
Hello I have a 1940 H and the oil line to the pressure gauge has a male nut with a compression fitting. Is this the orignal hook-up or has it midified? The gauge I took off is all smoked up so I can not tell if the gauge is orignal. I'm trying to determan what new gauge to buy.
Thanks
Carl from Michigan
Nebraska Cowman
07-27-2006 12:19:37
 Re: Oil pressure Gauge line Fitting in reply to Elk Farmer, 07-27-2006 12:05:50
Yes that should be right
brainerd dave
07-27-2006 12:18:37
When I replaced the oil pressure gauge on my '40 H, I needed an additional brass fitting on the back of the new gauge that the original oil line could connect with. I don't know the part number off hand, but the IHC guy knew what it needed and had a whole box of them in stock. The way I understood it, they don't make the gauge with the original fitting any longer.
