Correct rim size for an H?
Mike CA
07-28-2006 20:44:10
I saw a couple H's and several more M's at a junkyard today. I compared their rim sizes, and they were almost identical. Is that correct? What is the specific diameter they are supposed to be for the H?
Turtle H
07-29-2006 06:53:15
 Re: Correct rim size for an H? in reply to Mike CA, 07-28-2006 20:44:10
The rims are the same diameter. It is the width of the rim that is different.
Mike CA
07-28-2006 21:48:14
The one's I measured were 40 inches. For both the H and the M. hmmmm
Don L C
07-29-2006 17:58:46
 Re: Correct rim size for an H? in reply to Mike CA, 07-28-2006 21:48:14
You must have measured from the outside edge..... the rim is 38"....the width depends on the tire size.....
26Red
07-29-2006 16:07:45
Last time I was at that junkyard I remember seeing so 40" tires... and thinking that was odd. But it suits the farm country they are in-lots of vegetable and orchard farms up there.
Nebraska Cowman
07-29-2006 04:56:09
That sounds about right if you measured at the lip of the rim. My money says they are 38 tires.
old
07-28-2006 22:17:06
But where did you measure them. I'f I remember right you don't measure the out side but you measure the area that the tire sits on so that would make them 38 plus the inch or so for each side. Yes there is also 40 inch tires out there and they also may have been an option but in my area I have never seen them on an H. I know the 3 Hs I have all have 38 inch tires on the rear of them.
Mike CA
07-28-2006 23:04:11
 Re: Correct rim size for an H? in reply to old, 07-28-2006 22:17:06
The tires were on them. So I measured from the edge of the rim across to the other edge of the rim.
old
07-28-2006 21:15:08
Every H I have seen or owned had 38inch rims on the rear. But I also think there was an option for a small size rim also just not as common
Van in AR
07-28-2006 22:46:26
 Re: Correct rim size for an H? in reply to old, 07-28-2006 21:15:08
Some of the british H's and those on cutoffs had 36" tires.
Van
RustyFarmall
07-29-2006 06:23:47
 Re: Correct rim size for an H? in reply to Van in AR, 07-28-2006 22:46:26
A few of the very early Hs and Ms did come on 36" rubber. I have seen a few.
