PTO Oil in 340
PaulW_NJ
07-29-2006 05:12:41
The PTO on my 340 U is the earlier "planetary type", based upon photos in the manual. The newer ones were a "clutch type". I pulled the drain plug and drained the reservoir (from the looks of it probably the first time ever . . . ). The manual says to refill the planetary type with 2 quarts of SAE 10, while the clutch type calls for 1 pint of HyTran. A friend says I can also use HyTran or equivalent in the planetary type as well - my NAPA dealer doesn"t carry SAE 10. Can anyone comment on this?
Thanks alot.
TDK
07-29-2006 06:00:09
 Re: PTO Oil in 340 in reply to PaulW_NJ, 07-29-2006 05:12:41
If it's the planatary-type, then it's the same as the 300/350/330 tractors and they use HyTran fluid in them.
Nebraska Cowman
07-29-2006 05:19:58
I'm sure you can use Hy-trans, Oil grades are much more forgiving than they were 50 years ago.
third party image
Gold for the mistress,
Silver for the maid.
Copper for the craftsman,
Cunning in his trade.
"Good" said the Baron sitting in his hall,
"But iron- cold iron - is the master of them all."
-Rudyard Kipling
