Order Farmall Cub Parts Online
1957 Cub Positive or Negative ground
Sam F.
07-29-2006 10:50:38
1957 Cub still 6 volt. Is it positive or negative ground ??
billde
07-29-2006 12:38:19
 Re: 1957 Cub Positive or Negative ground in reply to Sam F., 07-29-2006 10:50:38
57 would be 6 volt pos ground.
old
07-29-2006 11:29:20
Should be + ground.
Sam F.
07-29-2006 11:55:22
 Re: 1957 Cub Positive or Negative ground in reply to old, 07-29-2006 11:29:20
That's kind of what I thought but I had seen somewhere that around 1955 a lot of Farmall's went to negative ground. Thanks
old
07-29-2006 12:05:20
 Re: 1957 Cub Positive or Negative ground in reply to Sam F., 07-29-2006 11:55:22
Most companys didn't go to - gorund till after 1960. but I can not be 100% sure I jsut know most before where + ground.
john *.?-!.* cub owner
07-29-2006 20:50:13
 Re: 1957 Cub Positive or Negative ground in reply to old, 07-29-2006 12:05:20
Farmall didn't go to negative ground till they changed to 12 volts.
old
07-29-2006 21:01:10
 Re: 1957 Cub Positive or Negative ground in reply to john *.?-!.* cub owner, 07-29-2006 20:50:13
I figured I was right but wasn't 100% sure
