kfox
07-29-2006 19:32:02
The X Rated Code List in reply to kfox, 07-29-2006 14:54:57
CODE # ON SERIAL # TAG MEANING X1 gasoline engine X1A gasoline, low speed gears X1B gasoline, 5000' altitude X1C gasoline, 8000' altitude Y1D rubber tires, swinging drawbar X1E gasoline, 5000' altitude, low speed gears X1F gasoline, high speed gears X1G gasoline, high speed gears, low speed gears X1H gasoline, high speed gears, 8000' altitude X1J gasoline, 7mph high speed gears,5000' altitude W1K battery ignition, hyd. pump drive, starting & lighting X1L gasoline, 7mph high speed gears, low speed gears, 5000' altitude X1M gasoline, 8000' altitude, low-low speed gears X1N gasoline, 8000' altitude, low-low speed gears, 7 mph high speed gears X2 modified Y2A modified, 5000' altitude Y2B modified, high speed reverse X3 kerosene X3A kerosene, low speed gears X3B kerosene, 5000' altitude X3C kerosene, 8000' altitude X3D kerosene, high speed gears W3E 7 mph high speed gears W3F I-4 transmission X3G kerosene, 7 mph high speed gears, 5000' altitude X3H kerosene, 7 mph high speed gears, low-low speed gears X4 shop mule X5 5000' altitude X5A 5000' altitude, 7 mph high speed gears X6 low speed gears X6A low speed gears X6B low speed gears X6C low speed gears X8 8000' altitude X9 high speed gears X10 10,000' altitude X11 undersize crankshaft X11S undersize crankshaft (replaced) W12 rubber tires W12A rubber tires, swinging drawbar W12B rubber tires, swinging drawbar, starting & lighting W12C rubber tires, swinging drawbar W13 swinging drawbar W13A swinging drawbar, starting or lighting X14 starting or lighting X14A battery ignition with starting or lighting and adjustable frt. axle Y15 U.S. ARMY AIR CORPS W16 over center hand operated clutch X17 distillate X17A distilate, 5000' altitude X17D distillate, 8000' altitude X18 unlisted option X19 special transmission X20 cotton harvester setup X20A cotton harvester, gasoline X20B cotton harvester, kerosene X20C cotton harvester, diesel X21 7 mph high speed gears, 8000' altitude X22 adjustable frt axle - heavy duty X22A adjustable frt axle X23 Auburn clutch X24 non-adjustable frt axle
