Super H clutch job
Greg Super H
07-29-2006 15:08:18
Help!.I just put my SH back together from a clutch replacement. However when I went to depress the clutch pedal, nothing happened. It feels like the throwout bearing is not making contact with the pressure plate.Ihave looked at the repair manual and everything seems to be installed correctly.Iwill gladly take any advise you could offer
Greg Super H
07-29-2006 17:38:43
 Re: Super H clutch job in reply to Greg Super H, 07-29-2006 15:08:18
Thanks to everyone . However,the problem is still there. Let me try to give you all alittle more imfo.I did not replace the old pressure plate,but I did have to replace the throwout bearing and the pilot bearing.I did notice that when i tightened down on the presure plate to the flywheel the fingers on the pressure plate began to compress in to the center.Is this normal?
Janicholson
07-29-2006 18:10:08
 Re: Super H clutch job in reply to Greg Super H, 07-29-2006 17:38:43
Yes it is. The problem may be that the combination of components is way different than before. Make the rod going from the clutch pedal to the little grank arm in the front longrer (maybe as much as an inch or so. The pedal should move only 7/8" to 1" away from the platform (measured at the point of contact) before it begins to feel firm and push the fingers farther in. If this still does not work, you may have put the disk in backwards and its drive hub is jambed against the flywheel (this does happen unfortunately) if so it must be turned around to correct the p[roblem or it will be ruined. Good luck, JimN
Janicholson
07-29-2006 15:58:14
Dave has it. Remove the bolts (look at your old clutch and see the holes) I hope you didn't get the pump back in before checking it! Go for it. JimN
Dave Slater
07-29-2006 15:45:21
Did the new presser plate have 3 bolts to hold it compressed? If so they need removed after installing.
KCSUPERMMAN
07-29-2006 15:37:18
Did you try to adjust the clutch peddle linkage? If the old clutch was worn thin, the linkage should have been adjusted so the old clutch would hold under a load.
