Compression test
Gordon Stenke
07-29-2006 18:21:17
Could someone tell me the compression should be on a Farmall M with a 264 and flat top pistons?
Gordon
Janicholson
07-29-2006 18:26:42
 Re: Compression test in reply to Gordon Stenke, 07-29-2006 18:21:17
If it is a all fuel/distillate, it could be as low as 85-90 psi (checked with throttle open and having been run recently)
If it has X1 in the serial # it should be in the range of 115-120
If X5 or X7 it may be 125-140
If it has been tweeked to do more, it may be higher.
JimN
Gordon Stenke
07-29-2006 19:49:10
 Re: Compression test in reply to Janicholson, 07-29-2006 18:26:42
Janicholson, It has a X1 suffic, thanks for the reply.
Gordon
