farmall b cultivision 1940?
dave crain
07-30-2006 05:32:49
thanks for all the response, however, the tractor is so rusty i cant find the serial no. the casting no. is 8638DD and on the tran it is 6832DA please respond if you know of anything. thanks--dave
CNKS
07-30-2006 17:02:35
 Re: farmall b cultivision 1940? in reply to dave crain, 07-30-2006 05:32:49
The date the block was cast is supposed to be behind the magneto, the engine serial is under the #1 spark plug, it will match the chassis serial provided the block is original.
Red Dave
07-30-2006 08:55:49
Those are casting numbers and will not help you determine the year.
Look for the engine serial number, if it is a 1940, and the block is original, it will be the same as the tractot serial number.
This link will show you where to look for the engine serial number:
