New H trans gears
matthies
07-30-2006 08:45:06
Is there any aftermarket places to buy the 4/5 slider, fifth gear, and the 1/R fork. thanks chris
Haas
07-31-2006 14:07:39
 Re: New H trans gears in reply to matthies, 07-30-2006 08:45:06
The slider gear is available from the place in DesMoines, IA that you can't post on this site because they don't contribute. The Super H gear is available from the place in Lennon Mich, that I don't think you can post either. These are after market gears and run about $200. As below, J weber says he has NOS gears. I don't know about the forks, Have not seen those. JW may have them.
tn terry t
07-30-2006 18:43:45
hey matthies i have bought bunches of farmall stuff from Wengers of Myerstown nuthin but top notch service from them they have a new 4th,5th slider a little pricey but nether the less
magman
07-30-2006 10:24:40
hello
old
07-30-2006 10:11:12
I have one H parts tractor and the tranny is all there
justin w
07-30-2006 09:41:46
Why buy reproduction when you can buy NOS.... I should have all the parts you need.. email me the part numbers you need, and I will get back to you.
RustyFarmall
07-30-2006 09:41:17
I doubt if anyone is reproducing those. You might check with your local Case-IH dealer on the off chance he might be able to find some N.O.S. parts, but other than that your only chance is used parts from a salvaged tractor. You might contact Nebraska Cowman.
