any Idea's on how to repair small tank
Paul G. in Mn
08-01-2006 14:43:40
I am working on parts of my early 39 M. My small gas tank the threaded port on the bottem has come loose from the tank. It looks like it may have been spot welded when new. Is that correct? is there any way I can repair this? I have anther off a 41 but they are not even close to the same. Can I braze this or respot weld it? It has not had gas in it in years so no fumes. Thanks Paul
Tom Windsor
08-01-2006 16:38:03
 Re: any Idea's on how to repair small tank in reply to Paul G. in Mn, 08-01-2006 14:43:40
i dont know how they did it, but the ones I have had contact with were soldered.
IaGary
08-01-2006 15:26:29
When I worked at the welding shop we would fill gas tanks clear full with water then dump it out and weld.
If we concerned that we didn't get all the gas fumes out we would stick a torch in from a distance or tied to a broomhandle.
But useing the water never once had a flare up.
If the tank has been empty for some time, there should be no problem.
Just make sure you get all the water out before remounting the tank.
Gary
Don L C
08-01-2006 15:06:22
Just in case there is a trace of fumes in the tank....here is what I do....put a open air hose into the filler....set pressure a about10 - 15 #.....mow go ahead and braze or soder it.....
Yugrotcart
08-01-2006 14:51:32
I'd just clean it up and braze it.
