baffle loose in M gas tank
Paul G. in Mn
08-01-2006 14:46:30
I am working on parts for my early 1939 M. One of the baffles in the bottem is broke from its spot welds. Is there a way to repair this? Will it hurt anything if I leave it? 39 tanks are different from other M tanks so would like to use this one. Thanks Paul
Janicholson
08-01-2006 18:59:07
 Re: baffle loose in M gas tank in reply to Paul G. in Mn, 08-01-2006 14:46:30
If you can fish it up to the filler hole, you could remove the tank, fill the it with running water, and bend it till it fits through the hole then live without it. JimN
Nebraska Cowman
08-01-2006 15:36:53
I would never sell a tank with a loose baffle but I've run my TO 20 Fergie several years with the baffle floating in the bottom. Can it spark as long as it's wet?
