questions?
FC Andy
08-02-2006 12:36:31
I"ve got 3 questions for you guys: 1. What is the proper way to determine the size of bottom of a plow? 2: Does anybody have any expirence with the 3 piece exhaut manifold of an 806 diesel? I had to replace my center section, an am wondering on the process to take them apart and put back together. It"s apart now, I used a torch and heated the center to get them apart, I"m wondering if that is what is needed to put the new one together. And 3: how many wheel weights would you guys run on the tires (non loaded) for a Farmall C and 1 bottom plow, and said 806 with 4 bottom? Thanks alot guys, just looking for some expertise here.
Pat H
08-02-2006 15:50:32
 Re: questions? in reply to FC Andy, 08-02-2006 12:36:31
I agree with Vet, 4 16's work good on my 806D.
I don't have it loaded with fluid and run 4 wheel weights per side on 18.4 x 34 Firestone Field and Road. Good tires - put them on about 10 or 12 years ago. The next set will be radials like I put on the 1066, really work good.
Hope this helps, Pat in Wis
Janicholson
08-02-2006 14:22:27
You can also measure from the tip of the share perpendicular to the land slide. A framing square works well. JimN
the tractor vet
08-02-2006 12:47:09
Well if ya got the maifold apart then that is 99% of the battel , now just clean up the pices and slide it back together and carbon will do the rest for resealing and as far as massuren the width of a plow massure between the beam and that is the width if ya try and amssure the shear then it is something like this a 14 inch bottm the shear will be ABOUT 16 inch long and a 16 inch shear will be ABOUT 18 inch long, like i said ABOUT . A 806 was designed as a 5 bottom tractor when new and would roll along with 5x16's in 4th low stick ahead as i did a lot of plowen with and 806 when they were brand new , but they work real nice with 4x16's as that is what i am pullen with mine i have a set of 710 4X16's that i pull with it and can run high 1st .
