Super A Hydraulic problem
Kyleg
08-03-2006 14:30:50
I have a 1954 Super A. The hydraulics were working but then all of the fluid was lost in the system and there were no visible leakes. I tracked this down to the front seal and rplaced it. Now the system works but it seems that the more it is used the less it works. Any thoughts?
Vern
08-03-2006 22:05:03
 Re: Super A Hydraulic problem in reply to Kyleg, 08-03-2006 14:30:50
Check the crankcase oil level. If oil runs out of the top petcock the hyd. pump seal is leaking fluid into the crankcase.
Vern
CNKS
08-03-2006 17:11:14
For starters, clean the filter screen, held by 4 bolts on the left side of the reservoir/control unit. If that does not work, pull the unit, disassemble and get a kit from Case-IH.
