H lights Questions
Elk Farmer
08-03-2006 16:31:56
You would think after all I have done with this H (With all of your help) I could figure out the head lights.
My first question, does the light resistor have to have the coating on the coil to work? and what happens if I remove the resistor? When I check the voltage at the terminal in the head light I get 6.2 volts but when I install the light reflector and bulb it does not work and the voltage drops to 5.1 volts. what is the best way to get a good ground. I have just repainted the tractor piece by piece.
Thanks to all of you. I couldn't have done It without all of your answers to my questions
Elk Farmer
Carl from Michigan
Randy S.E.-MN
08-04-2006 06:06:54
 Re: H lights Questions in reply to Elk Farmer, 08-03-2006 16:31:56
I"ve run into that several times. I"ve learned to paint the light bar with the light housings and mounting clamps untouched, (remove the retaining rings and innards and prep-paint) then the only issues for ground potential problems are the u-bolts or the steering post to deck bolts.
jossette
08-03-2006 16:52:22
The best way to do that without reckin the paint is to run another wire to the light and back to the battery for ground.
Paul G. in Mn
08-03-2006 16:49:36
I just got done redoing my lights for my 39 M and had the same problem when I put them back togather. I ended up takeing a small piece of sand paper to the inside the houseing were the reflector contacts and sanded it just a bit. Also on my 39 there is a screw used as a ground from the housing I also sanded the back side of that too. The resistor I believe is for the dimming of the lights, that might be why you drop down to 5 volts
