1946 Farmall Super A Basic questions
JD Lost in VA
08-03-2006 20:49:07
This may sound dumb, but I have been reading like mad and cannot find the simplest of information.
I have a super A, sat for 3 years, but I parked it and it purred like a kitten when shut off.
I need to find out what all the controls are on it.
What the switches do and how the magneto works inside.
I just bought a mini farm, so I am flat broke.
I know I am going to have to buy the manual to rebuild the carb and the hyd pump, both of which leak like mad...
Do any of you have a simple guide as to where the fluid levels are supposed to be checked, what all the levers are for, what the switches do...and how the points and mag should be dealt with?
This darlin is complete and besides a GM 12 volt alternator, not screwed up at all.
I sure would appreciate any help someone could give me, even a picture with some text and pointers as to what is what.
Is there anyone here in VA?
I am in Bedford county.
Thanks in advance!
JD
JD lost in VA
08-05-2006 10:43:39
 Re: 1946 Farmall Super A Basic questions in reply to JD Lost in VA, 08-03-2006 20:49:07
third party image
I was told this fuse is not stock.
It looks stock, but I do not know the history of this machine for the first forty years of its life.
who knows???
Keith-OR
08-04-2006 11:40:35
Ok JD, you can now go to this website for info on Super A tractor.HTH
Keith & Shawn
Hit reply then you will b
08-04-2006 11:43:10
 Re: 1946 Farmall Super A Basic questions in reply to Keith-OR, 08-04-2006 11:40:35
HTH
Keith-OR
08-04-2006 08:52:37
JD, try again later. I was just there last nite looking at another manual. I tried a few minutes ago and it would not come up, must be having server difficulties....:>((
Keith & Shawn
for Bob
08-04-2006 06:34:13
Bob, that link would not work no mater what I tried
Bob
08-04-2006 23:32:39
 Re: 1946 Farmall Super A Basic questions in reply to for Bob, 08-04-2006 06:34:13
If you are addressing that to me, the link works fine from here, when I cut and paste it into either IE 6, or Firefox. Really, won't it work for you?
(Hot links to the Cub Manual Server won't "take" on this site.)
Link
JD lost in VA
08-04-2006 05:58:38
Yeah, um, thanks.
I am aware that I "ought to buy the manuals" so, I am "just going to do it."
I was just hoping there was something online that would help me to get the thing fired, so it could be moved out of the way easier while waiting for the manuals.
For those of you who emailed and were actually helpful...thank you very much!!
Nat 2
08-04-2006 12:52:52
 Re: 1946 Farmall Super A Basic questions in reply to JD lost in VA, 08-04-2006 05:58:38
"Get the manuals" may not have been the answer you wanted to hear, but it's still good helpful info. There is a lot to operating these tractors; the manuals generally run 50-70 pages, which is a LOT more than what you could reasonably expect someone to type in for you. Plus there are pictures, versus a text-only description which is open to some serious interpretation.
If it's been settin' for 3 years, though, it's probably gonna take a lot more than knowing which lever does what to get it fired. Sometimes you can luck out and the engine won't be set up, the gas tank and carb will be dry, rust-free and varnish-free, and the plugs, wires, and mag will be usable. A friend of mine bought an old M out of a barn that had been sitting for at least 10 years. All he did was put a battery and some gas in it; it fired right up and he drove it home that day.
More likely, you'll be looking at a rusty gas tank, a gummed-up carb, and/or no spark. If your on a time table to get it moved, you may just want to bite the bullet, break out the tow chain, and move it somewhere that you can work on it as you have time...
Basic switches, assuming stock:
Ignition is the push-pull switch. Pull for ON.
Lights are the twist knob. Full left is OFF.
Gear shift is the stick coming out the top of the platform to the left of the seat. Gear pattern is cast into the platform just ahead of the lever.
Clutch is the left pedal. Push to shift
Left brake is the middle pedal. Push pedal by itself to skid the tractor to the left. Right brake is the right pedal. Push pedal by itself to skid the tractor to the right.
Push both brake pedals at the same time to stop the tractor.
Throttle is the lever with the ratchet on the steering post. Back is lower RPM, forward is higher RPM.
Hydraulic lift arms are the two other levers on the steering post. Back rolls the arms toward the rear of the tractor. Forward rolls the arms toward the front of the tractor. Various attachments translate the rotation of the arms into linear motion to lift and lower various implements.
Power take off, the splined shaft sticking out the back of the tractor, is controlled by a lever that should be on the left side of the seat.
Hope this is helpful.
JD the rude from VA
08-04-2006 20:13:21
 Re: 1946 Farmall Super A Basic questions in reply to Nat 2, 08-04-2006 12:52:52
I was not asking anyone to type a book for me. I would have thought the manuals had been scanned and turned into .pdf by now.
I was shocked to search all over the web and not find this info somewhere.
Lord knows if you ask anything about a 4X4 truck, there are guides and pics all over the place.
Same thing with:
Corvettes.
Boats.
Airplanes.
Lawnmowers.
Old radios.
Windmills.
Solar water heaters.
Carpentry.
Appliance repair.
HVAC.
Car Stereo.
Painting.
Carving.
Rock climbing...etc...etc.
To find this much interest in tractors and so little in the way of home brew guides and digital pics on the web is truly shocking to me.
Nat 2
08-04-2006 12:54:33
Oops, forgot the choke and starter levers.
Not sure where those are on an A, but you should be able to trace a rod running from the side of the carburetor back to the operator's platform. That's the choke. There should be a linkage running from that switch on top of the starter back to another rod on the operator's platform too. That's the starter.
Jd lost in VA
08-05-2006 12:47:02
 Re: 1946 Farmall Super A Basic questions in reply to Nat 2, 08-04-2006 12:54:33
BTW, the reply was not aimed at you, I replied in the wrong spot. I appreciate your help very much!
scotty
08-04-2006 04:43:28
Mornin JD, In addition to the operators manual you should get a service manual for the tractor and the service manual for the touch control, its very inexpensive and well worth the $8.95 from Binder Books !!! The serial tag on the left seat support bracket will have your serial # and you can find out what year tractor you have ! The Super A started production in 1947.
The rebuild kit for your touch control hydraulic unit is available from your loacal Case IH dealer for about $100.
scotty
Mikey D
08-04-2006 03:46:48
The questions you asked about your Super A (1947 - 1954) are answered in the "Super A Operators Manual" which is available from Binder Books. It contains information worth the money.
mike
Ron in Nebr
08-03-2006 21:54:04
I'm not positive, but I think that the "Supers" didn't come out 'till about 53 or so...at least on the bigger tractors. So, assuming the A's were the same, yours is either not a Super A or not a '46. Does it have the touch-control hydraulic system? These came out on the Supers I think. If it does, there should be two arms that go out and up, used to raise or lower various implements, one on either side below the gas tank. There will be two levers that control these arms just to the left of the throttle, which is just to the left of the steering post.
As for controls- the throttle lever, like I said, is immediately left of the steering post. It'll have a sawtooth bracket that holds it in place. If it has the touch control levers, they have guides beside them with adjustable stops.
Other controls will be- on the left side of the battery there'll be a rod with a loop on the end that runs down to the carb. That's the choke. An identical rod on the right side will go to the starter motor- that, funny enough, is the starting rod. There should be a push-pull switch on the panel that the ampmeter is on, thats the on-off switch. A larger round rotating switch on that panel ran the lights. I'm sure you know what the gearshift is and where it's at. Last thing I can think of is to the immediate left rear of the left seat bracket there should be a small lever sticking up- that's your pto lever.
Most of the things(trans/rearend, final drives, steering box, etc. should have a fairly obvious plug on the sides of them that is for fluid levels. There's a larger plug on top of the trans near the shifter to fill it. Like previously mentioned, you NEED to get a manual if you're gonna run this tractor much. They can be ordered online through the links on the left of this page.
I'll let someone else tackle your mag questions! Good luck!
Ron in Nebr
08-03-2006 21:57:53
 Re: 1946 Farmall Super A Basic questions in reply to Ron in Nebr, 08-03-2006 21:54:04
OOPS- reread your post and noticed the part about the hydraulic pump leaking, so disregard the part above where I asked ya if it has hydraulics!!!
Another thing, you can look up your serial number(should be on a plate attached to one of the seat brackets) at a link to the left of this page and it'll tell ya for sure what year tractor ya have.
Bob
08-03-2006 21:50:10
 Here's some help... in reply to JD Lost in VA, 08-03-2006 20:49:07
Link
You'll have to cut and paste the address above into your browser, if the link doesn't show up!
Jd lost in VA
08-05-2006 12:45:28
 Re: Here's some help... in reply to Bob, 08-03-2006 21:50:10
THANK YOU SOOOOO OOOOO OO MUCH!!!
This is EXACTLY what I was looking for!!!
It came back on line, cause when I tried it today, it worked like a charm!!
I appreciate it very much!
Mike CA
08-03-2006 21:18:24
You know you need to buy the manuals, so you just ought to do it.
Jd lost in VA
08-05-2006 10:40:20
 Re: 1946 Farmall Super A Basic questions in reply to Mike CA, 08-03-2006 21:18:24
third party image
Here it is...
I have no spark.
I don't know what to think...I was told it is a mag..??
