Super C Brakes leaking oil
Beninarkansas
08-04-2006 10:00:01
How do you get the round plates off the brake shaft to replace the seals? Tranny oil is leaking from around splinned brake shaft. They are the round steel plates mated to the cast iron of the tractor. Thanks for your know how! 1952 Super C
Benin arkansas
08-07-2006 06:44:54
 Re: Super C Brakes leaking oil in reply to Beninarkansas, 08-04-2006 10:00:01
Thanks Guys! I don't like to start prying on stuff till I am sure it's OK to do it. Don't know what I'd do without you all!
teddy52food
08-04-2006 19:58:29
I resealed mine a couple years ago. Super c has disk brakes. After taking out the bolts, the cover, disks and actuater come off . the housing that has the seal is in the case fairly tight with an o ring seal around the outside. you can get it out by driving small screwdrivers on opposite sides then use pry bars. Replace the seal and o ring and reassemble.( hope I didn"t forget something)
Wayne Swenson
08-04-2006 19:52:45
Locate the small notches on the plate where it touches the transmission housing, insert a pry bar & have at it. There is an o-ring that makes it hard to remove.
CNKS
08-04-2006 14:25:14
Not sure I know what you mean. Remove the cover, band and associated parts and drum, then carefully pry or dig or pull the seal out. There is nothing else other than washers and dust seals to remove.
CNKS
08-04-2006 19:55:42
 Re: Super C Brakes leaking oil in reply to CNKS, 08-04-2006 14:25:14
You said Super C, has disk brakes, info I gave was for a C, sorry.
