H fast 4th
Rich Griffin
08-04-2006 18:24:21
Does anyone know the part numbers for the gears that I need in order to install a fast 4th in a '45 Farmall H. How much difference in speed will I see?
Are these gears available? I checked with C/IH and they are no longer be bought and they didnt really know the part numbers for sure. Thanks.
Shovelman
08-04-2006 18:52:51
 Re: H fast 4th in reply to Rich Griffin, 08-04-2006 18:24:21
Rich,
You will need the 4/5 sliding gear, #62396D and the 3/4 driving gear, #65272DX. Also needed is a countershaft spacer, #65273D.
This will give you the 7 mph 4th gear that makes all the difference for raking and tedding.
The gears are somewhat rare but can still be found if you look hard enough. They will even show up on eBay once in a while.
Good luck,
Scott
