Super H distillate?
Craig T
08-04-2006 19:54:37
I have a book that says there were no Super H distillates made. However, a neighbor has a Super H with the distillate manifold, radiator shutters, and start on gas tank. It is all factory and it is a Super H by the serial tag. Can anyone explain this?
dej(JED)
08-07-2006 05:57:34
 Re: Super H distillate? in reply to Craig T, 08-04-2006 19:54:37
I have a gasoline M with an MD tag on it.
randy hall
08-05-2006 09:22:59
i'd write down the name of the author of your book and be sure not to buy anymore that he has written.
MJ in the UK
08-05-2006 05:59:47
I find this post very intresting as here in the UK all spark ignition tractors were the T V O (disterlate) type. UK built Farmall Ms and NW6 tractors were offerd with a T V O engine till the end of production in 1958. t v o stands for tractor vaporising oil. MJ
MJin the UK
08-05-2006 06:01:28
 Re: Super H distillate? in reply to MJ in the UK, 08-05-2006 05:59:47
Sorry folks but the NW6 tractor should be BW6 mj
Pat H
08-05-2006 02:07:37
Of the 475 super H's that I have listed on the serial number list 13 tractors have the AJ suffix on the serial number plate and the A suffix stamped on the motor serial number. The latest AJ I have listed is in Colorado with a number of 28846AJ, so it was available until at least close to the end of super H production, probably later as CNKS and others have indicated. Would like to know the serial number of the tractor in question if possible. Thanks, Pat in Wis
Craig T
08-05-2006 05:51:10
 Re: Super H distillate? in reply to Pat H, 08-05-2006 02:07:37
Sorry, it isn't my tractor, if I find out I'll let you know.
Mikey D
08-04-2006 20:56:12
Explanation: The book is wrong. I've seen one or two.
mike
Steven@AZ
08-04-2006 20:52:19
Distillate was available through the 450 for sure.
john *.?-!.* cub owner
08-04-2006 20:34:33
Check the serial numbers. If it was oriignally a distilalte, both the chasis and engine seiral number should end in A for distiallte, or B dor kerosene.
Tom Windsor
08-04-2006 21:13:24
 Re: Distillate -v- kerosene in reply to john *.?-!.* cub owner, 08-04-2006 20:34:33
I do not know the difference between a distilalte and a kerosene engine. I have an H or two back there that have different length valves than the gasoline engines.
Craig T
08-04-2006 20:39:04
 Re: Super H distillate? in reply to john *.?-!.* cub owner, 08-04-2006 20:34:33
If I remember right the serial tag did have an A stamped at the end of the serial number.
CNKS
08-04-2006 20:01:21
A lot of the books have many mistakes, meaning the author did not research and confirm the info and merely repeated what someone else said. Sort of like the current crop of TV "journalists". I will exclude Guy Fay and Ken Updike, and maybe one or two others from this statement. I think distillate engines were available thru the 00, possibly 50 series, ie until about 1958.
Craig T
08-04-2006 20:15:19
 Re: Super H distillate? in reply to CNKS, 08-04-2006 20:01:21
This particular book wasn't written by either of those guys but the author has written a couple other books on Farmalls that I have. I'll keep looking at a few other books.
CNKS
08-04-2006 20:26:56
 Re: Super H distillate? in reply to Craig T, 08-04-2006 20:15:19
But, distillate was still an option on Super H's, yours is not the first I have heard about. Guy Fay is the one who mentioned it being available on the "later" tractors, I do not remember the termination date, but I am positive that it could be on the tractor you described. Guy is THE authority on those tractors.
Craig T
08-04-2006 20:36:54
 Re: Super H distillate? in reply to CNKS, 08-04-2006 20:26:56
The castings on this tractor date back to early 1953. It isn't a early Super H. But you are right, it could have been an option that this author didn't know about. I wish Guy would just reply and set us all straight right now.
Harold H
08-05-2006 17:30:26
 Re: Super H distillate? in reply to Craig T, 08-04-2006 20:36:54
Distillate was available thru the end of the 350/450 series tractors.
Harold H
