c-superc thermostat
R Fink
08-05-2006 12:02:28
added water pump to c block ,am trying to add a thermostat. thermostat sits in the neck is there some kind of spacer and snap ring the hold it in place?
El Toro
08-05-2006 15:08:00
 Re: c-superc thermostat in reply to R Fink, 08-05-2006 12:02:28
How's the Super C running? Still working on the green stuff? Hal
Brownie 45
08-05-2006 14:11:56
Originally had a butterfly looking wire which had 4 loops which fit in a recessed groove on the inside of the water outlet neck. Don't know if it is still available or not. This wire held the thermostat in place. Sometimes.
Jack in OH
08-05-2006 14:10:45
Yes , there is a spacer and a wire clip that hold in the new style thermostat. They are available from Case dealer, I recently purchased them. The new thermostat is a lot thinner than the old style and requires a spacer.
Jack
CharleyFarmall
08-05-2006 20:10:11
 Re: c-superc thermostat in reply to Jack in OH, 08-05-2006 14:10:45
My case dealer had no idea that there is a spacer and does not list the part anywhere. Happily on the current Super C I have a good old brass thermostat that still works. I will have to deal with it on my other one though.
