H won't fire up
hbauer
08-06-2006 06:51:38
Justwhen I thought I had it running great, my H now refuses to start. The batter is charged and cranks good. Put in a new 6 volt coil. Nothing.
Distrib cap looks okay. Rotor looks alright.
Gets gas to carb...appears to be ignition.
About the condensor, ignition...where is it. Not inside dist...is it outside? HELP
Hbauer
old
08-06-2006 08:58:50
 Re: H won't fire up in reply to hbauer, 08-06-2006 06:51:38
Time to trouble shoot where the problem is. Check for spark. If you don't have a good blue spark it will not run. Cap and rotor are just 2 parts out of around 10 that have to be right for thing to work. If you haven't replaced them I would get new points and condenser and put them in and go from there.
RustyFarmall
08-06-2006 07:04:51
The condensor lives underneath the cap that is under the rotor. You will find the contact points in the same place. My guess is that the points are dirty, corroded, etc. Replace them along with the condensor.
