Super H oil leaking onto disk brakes
Greg Burns
08-06-2006 08:36:56
I have a 1953 Super H. It appears on one side that I am leaking oil into the disc brakes. I take the disc out and the brake assembly out but can't seem to see a seal. Ha anyone had this problem and how easy is it to fix. Also, in the brakes there is a linkage that hooks to the unit that activates the brake and then hooks to the rod running to the brake pedal. Mine where the pins hook through are badly worn can I buy these new somewhere. I seem to be able to locate other brake parts but not these. Thanks in advance for your help.
Andrew Z
08-06-2006 14:31:58
 Re: Super H oil leaking onto disk brakes in reply to Greg Burns, 08-06-2006 08:36:56
you need to pull the plate about 1 1/2" that is on the side that is closest to the trans. just take that off and the seal is in the indside of that. Its pretty easy.
Andrew
