'39 H - Knocking sound from front wheel????
Jim Joanie
08-06-2006 10:05:30
Talking to seller of a 39 H, in email discussion he mentions a knocking sound from front wheel, (his email below), wondering what this may be - front wheel bearings? Loose front wheel? Steering cam rocking back and forth? Thanks
Just drove it to a local tractor show this past weekend a mile each way, and did not notice any whine or noise. It shifts fine with no wobble in the front end. There did seem to be an occasional knocking noise coming from the front wheel? Steering is pretty tight.
KRUSS
08-06-2006 14:14:58
 Re: '39 H - Knocking sound from front wheel???? in reply to Jim Joanie, 08-06-2006 10:05:30
definitly loose lugs: not a big deal to fix, but something that does need fixed if you are going to be using 5 th gear.
Brownie 45
08-06-2006 14:14:20
Had a 350D which had a wheel bearing bad, & it sounded like the whole front end was going to fall off. New bearings & races fixed everything up.
El Toro
08-06-2006 10:27:38
Iwould agee with Gordo. Check those wheel lugs. Hal
Turke Bros Farms
08-06-2006 10:20:54
right you are that is very common.
GordoSD
08-06-2006 10:14:49
Knocking or clunking sounds usually from loose lug nuts.
Gordo
Harley
08-06-2006 11:11:54
 Re: '39 H - Knocking sound from front wheel???? in reply to GordoSD, 08-06-2006 10:14:49
Yep, and if they ain't loose now, they probably were sometime in the last 60 years and the holes in the rim or the hub might be eggshaped. BTDT Harley
